Group: DynoMotion Message: 11682 From: himykabibble Date: 6/11/2015
Subject: Gracefully Handling USB Disconnect
One of the many details I never got sorted to my satisfaction in my old app is the way USB disconnects were handled.  If the KFlop was plugged in when the app is started, and never gets unplugged, life is good.  But if the USB disconnects, the app knows it has disconnected, but I was never able to get it to recover once the cable was plugged back in.  KMotion.exe handles the situation nicely, but I've never been able to decipher enough of the KMotion,exe code to understand what its doing.  I notice the "SimpleFormCS" sample app behaves the same way as my app.  Is there any example code that show how to get it to reconnect?
Ray L.
Group: DynoMotion Message: 11683 From: himykabibble Date: 6/11/2015
Subject: Re: Gracefully Handling USB Disconnect
Well, at least at the first level, it turns out to be simple - when the disconnect occurs, I dispose the KM object, and create a new one.  I do this ever 100 mSec, and eventually it re-connects.
Something odd is happening with the as-delivered app - This line in SendCommand_Click are throwing exceptions that cause a disconnect:
 KM.CheckIsReady();
Ray L.
Group: DynoMotion Message: 11684 From: geraldft Date: 6/12/2015
Hi Ray
I have used the VB Jogger.net examples as a base for working from, and they handle reconnect ok.  Perhaps you can get some clues from there?
Regards gerald
Group: DynoMotion Message: 11687 From: himykabibble Date: 6/12/2015
Gerald,
I'll take a look at that.  Thanks!
On a related note - there's another behavior I've never understood.  With my old app, I can start my app, then start/stop/whatever KMotion.exe, and all is fine   But if I start KMotion.exe first, my app is unable to find the KFlop.  There must be something I need to do to be able to "share" the KFlop with KMotion.exe.  Any idea what it is?
Ray L.
Group: DynoMotion Message: 11688 From: geraldft Date: 6/12/2015
It sounds related to the problem of reconnecting.  With the Jogger example it is possible to have both programs open at the same time.  So again if you look at that you may solve both problems!
Even so - I have found that Kmotion will often crash when I close my own application.  But the other way is ok - ie. always close Kmotion before closing  your app or Jogger...
Gerald
Group: DynoMotion Message: 11689 From: himykabibble Date: 6/12/2015
I'm not off to a very good start.  I've been unable to get  any of the example apps to run wilthout problems.  Several just throw exceptions before the GUI even comes up.  The only one that sorta-kinda works is SimpleForm, which lets' me send the "version" command maybe twice, before it throws an exception, and/or simply stops talking to the KFlop.  They all build without error.  What am I missing?
Ray L.
Group: DynoMotion Message: 11690 From: TK Date: 6/12/2015
Hi Ray,
Do the pre-compiled binaries work correctly?
Are you using Debug or Release Versions?
Have you built the libraries with BuildAllLibs.sln?
Are all binaries targeted to the correct Directory?
What KMotion Version are you running?
Did you Flash the New Version in KFLOP?
What exception do you get?
Can you run from Debug to see when/what caused the Exception?
On Jun 12, 2015, at 10:49 PM, jagboy1964@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Ray L.
Group: DynoMotion Message: 11692 From: himykabibble Date: 6/13/2015
1) I get the same behavior from the pre-compiled binaries
2) I've built them both for Debug and Release, and get the same behavior either way.
3) No, just using the as-installed DLLs.  Do I NEED to rebuild them??
4) What is the correct directory to target?
5) Using v432, and I've installed it twice, just to make sure no install problems.
6) Yes, I FLASHed the board as soon as I installed v432.
7) SimpleFormCS fails VERY consistently.  I open the app, click Send, and the Version command runs successfully.  I click Send again, and it again runs successfully.  I click Send a third time, and "Version" displays in the output window, but no response from the board.  I click Send again, and the Unhandled Exception dialog pops up, with the Exception Tet shown below.
8) I'm afraid I don't recall HOW to debug the DLLs.  You'll need to refresh my memory....
************** Exception Text **************
KMotion_dotNet.DMException: General Exception thrown :  Caller - [KMotion_dotNet.KM_Controller] :: Member - [CheckIsReady]
   at KMotion_dotNet.KM_Controller.CheckIsReady()
   at SimpleFormsCS.Form1.SendCommand_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.8009 (FX35W81RTMGDR.050727-8000)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SimpleFormsCS
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/KMotion432/KMotion/Release/SimpleFormsCS.exe
    Win32 Version: 2.0.50727.8015 (FX35W81RTMGDR.050727-8000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
KMotion_dotNet
    Assembly Version: 1.0.1.0
    Win32 Version: 1.0.1.0
    CodeBase: file:///C:/KMotion432/KMotion/Release/KMotion_dotNet.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
---In DynoMotion@yahoogroups.com, <tk@...> wrote :
Hi Ray,
Ray L.
Group: DynoMotion Message: 11695 From: himykabibble Date: 6/13/2015
BTW - If it matters, this is Win8.1 64-bit...
Ray L.
Group: DynoMotion Message: 11696 From: Tom Kerekes Date: 6/14/2015
Hi Ray,
Please use the latest Test Release 4.33l for development.  There have been many fixes and improvements to the .NET libraries and examples since V4.32.
You should rebuild the debug libraries if any are missing.
All the binaries should reside in either the \KMotion\Release or \KMotion\Debug so they can find each other.
To Debug select Debug Configuration in VS, set break points, run or Step through code.
Group: DynoMotion Message: 11697 From: Tom Kerekes Date: 6/14/2015
Hi Ray,
It shouldn't matter.
Group: DynoMotion Message: 11700 From: himykabibble Date: 6/14/2015
With 4.33i Release, I get exactly the same behavior - SimpleForm always wierds out after two Version commands..  With 4.33i Debug, I can execute more commands before it  wierds out (sometimes as many as 10), but it always wierds out in the same manner as the Release version eventually.
I'll try debugging in a bit...
Ray L.
Group: DynoMotion Message: 11701 From: himykabibble Date: 6/14/2015
I must be missing some setting....  I set a breakpoint on the KM.WriteLineWithEcho(Command.Text); line in SendCommand_Click.  When I click Send it breaks on that line.  I then hit F11 (Step Into), and it skips over the line to the next line!
Ray L.
Group: DynoMotion Message: 11703 From: himykabibble Date: 6/16/2015
Any ideas?  I'm dead in the water here....
Group: DynoMotion Message: 11705 From: Tom Kerekes Date: 6/16/2015
Hi Ray,
Please use Test Version 4.33l ('l' not 'i').
I'm not able to reproduce the problem.  I did the following:
#1 running lenovo laptop AMD A6 W8.1 64
#2 fresh install of KMotion433l
#3 connect KFLOP (USB Powered)
#3 flash New Version then exit KMotion.exe
#4 cycle power (remove/reconnect USB)
#5 run \Release\SimpleFormsCS.exe
#6 push Send "Version" 100 times
Also tried \Debug\SimpleFormsCS.exe 100 times
Upgraded USB drivers to 2014 version included in KMotion433l still can't see any problems.
Maybe there is an issue with your PC?  Do you have other KMotion Versions installed on the PC?  Any special Windows PATH settings?  Did you install dlls to the GAC?  Maybe an issue with .NET?  CAn you run KMotion.exe and send Version many times without error?
Group: DynoMotion Message: 11706 From: Tom Kerekes Date: 6/16/2015
Hi Ray,
That is more of a Visual Studio Question.   Google Visual Studio Stepping into C++ or unmanaged code.  Such as:
Group: DynoMotion Message: 11714 From: himykabibble Date: 6/17/2015
It appears I am screwed.... VisualStudio 2013 Community does not support debugging of unmanaged code.  Am I the only one who finds the example PC apps don't work?
Ray L.
Group: DynoMotion Message: 11715 From: TK Date: 6/18/2015
Hi Ray,
What makes you say that?  I believe VS Community 2013 is supposed to be the same as the full VS Pro Version.
Have you tested if the pre-compiled binaries run correctly?
I'm not aware of anyone else having trouble with the examples.
On Jun 17, 2015, at 10:25 PM, jagboy1964@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Ray L.
Group: DynoMotion Message: 11716 From: himykabibble Date: 6/18/2015
I can find no option for enabling unmanaged code debugging.  It is supposed to be in the Solution properties, Debug tab, and it's not there.  I did find numerous references for the Express versions indicating that unmanaged debugging was explicitly disabled.
Yes, I have run the pre-compiled binaries, both Debug and Release, and all beahve the same way.  The Debug versions will run slightly longer before going wonky, but none of them run for long before throwing exceptions and ceasing to function.  Both 4.32 and 4.33i behave exactly the same way.
Ry L.
Group: DynoMotion Message: 11717 From: himykabibble Date: 6/18/2015
The same thing happens with v430, which is the version I've been using on the machine for a long time.  I can do whatever I want KMotion.exe with no problems, so this appears to be something in the dotNet interface.  One more thing I will try today is running the sample apps on my machines PC, which runs v430 under Win7, whereas I'm having these problem on mu laptop, which is Win8.1.
Ray L.
Group: DynoMotion Message: 11718 From: himykabibble Date: 6/18/2015
One other data point - If I open KMotion, it works fine.  I then open SimpleFormCS, and click Send a few times.  It hangs.  At that point, KMotion is also hung, and only comes back to life after I close SimpleFormCS.
Ray L.
Group: DynoMotion Message: 11719 From: himykabibble Date: 6/18/2015
Hate to tell you, but I get EXACTLY the same result, running on my machines PC.  Different computer, different OS (Win7 vs Win8.1), different KFlop board, different KMotion version (v4.30 vs v4.32 and v4.33i).  This CAN'T be just me....
Ray L.
Group: DynoMotion Message: 11720 From: Tom Kerekes Date: 6/18/2015
Hi Ray,
I remember now that CheckIsReady .NET issue was fixed in Version 4.33j.  See:
I previously asked you to use Version 4.33l not 4.33i but you didn't seem to read that part. 'l' = lower case "L"
CheckIsReady might not have been the best example thing to start with as most applications would never use it.  Normally an App would know exactly what to expect back from KFLOP for any request it made.  But with the Console Screen case where user are just typing random script commands and we don't know what to expect back we just keep reading until we see "Ready".
I tested Visual Studio 2013 Community for debug stepping into the libraries and noticed at first it would not step into them until after I re-built the libraries.  I believe the .pdb (Program Database) files are needed.
#1 Fresh install of 4.33l
#2 open/upgrade BuildAllLibs.sln in VS2013
#3 change line (~333) in \TCC67\tcc.c (to fix new incompatibility conflict with new compiler libs)
from
    #if defined(WIN32) || defined(TCC_UCLIBC) || defined(__FreeBSD__)
to
    #if (defined(WIN32) && (_MSC_VER < 1800)) || defined(TCC_UCLIBC) || defined(__FreeBSD__)
#4 Rebuild Solution Debug and Release
#5 open/upgrade SimpleFormsCS.sln with VS2013.sln
#6 right click SimpleFormsCS project | Properties | check Enable Native Code Debugging
#7 set breakpoint at             KM = new KMotion_dotNet.KM_Controller();
#8 run + hit breakpoint + Step into (works !!)
#9 "step over" down to                 KM_dotnet_Interop_New(ref _InstanceHandle, _BoardNumber);
#10 "step into" (works!!!)
Group: DynoMotion Message: 11722 From: himykabibble Date: 6/18/2015
Yes, I read your post as 'i' not 'l', in part due to this God-awful new Yahoo interface....  You can't select text in a message you're writing?  WTF are they thinking??  The old I/F was awful.  This new one makes awful look good in comparison...
Anyway, I'm installing 4.33 ELL now.
"CheckIsReady might not have been the best example thing to start with as most applications would never use it.  Normally an App would know exactly what to expect back from KFLOP for any request it made.  But with the Console Screen case where user are just typing random script commands and we don't know what to expect back we just keep reading until we see "Ready"."
What I've been after all along, per the title of the thread, is understanding how to gracefully handle USB disconnects, the way KMotion does.  With my current app, the app crashes - not good!  I was told to look at the dotNEt examples, and SimpleForm seemed the closest to what I wanted, but now I'm confused, as you seem to be telling me CheckReady is not the way to go.  So what IS the right way to go?  How does KMotion do it, or, more to the point, how would you implement KMotion using dotNet to get the same robust behavior?  I spent a huge amount of time on it before, and couldn't come up with anything that worked.
Ray L.
Group: DynoMotion Message: 11723 From: himykabibble Date: 6/18/2015
With 433l, the apps seem happy, and DLL debugging is working.  Thanks for figuring that out.
One step missing from your instructions - You have to download and install a VS add-on to support non-Unicode character sets used by the MFC apps.
Now, on to my real problem?
Ray L.
Group: DynoMotion Message: 11724 From: Tom Kerekes Date: 6/18/2015
Hi Ray,
CheckIsReady is unrelated to how to handle USB Connects/Disconnects.  As I tried to explain previously CheckIsReady it only relates to the special case where a User enters Random Script commands and you want to send them to KFLOP and display the returned strings including the final "Ready" String.  CheckIsReady doesn't have anything to do with whether the USB connection or KFLOP is connected and ready.
So we still recommend for you to see how SimpleFormsCS handles USB being connected an disconnected.  The basic strategy is something like:
#1 for all status every windows timer (~ 100ms) checks with if (KM.WaitToken(100) == KMOTION_TOKEN.KMOTION_LOCKED).  This will immediately fail if no boards have been present or the board has been disconnected so don't attempt to update any status.  If a board is present it should be able to get control of the board within 100ms unless some other App is being a real Hog of KFLOP and not releasing the token.  So if this is successful then read all your status, release the Token, and update all your screens.  Note that if while reading status the board disconnects one of the reading status calls will correctly create an error.  No further status reads should then ever be attempted until the WaitToken again succeeds indicating the board has somehow re-connected.
#2 any button or action to do something to KFLOP (run job, jog, etc) will fail if KFLOP is disconnected.  Your App should expect that and if you are doing a sequence of things to KFLOP the first detected error should prevent any further actions to KFLOP.
#3 You App should never lock the Token and never return it.  If you do so then other Apps like KMotion.exe are likely to hang and lock up.  Some library commands like WriteLineReadLine lock the Token internally.  If you kill your Threads while they are making such a call there is a chance of leaving the Token Locked forever.  Request your Threads to terminate themselves in a clean manner to avoid this.
Group: DynoMotion Message: 11725 From: himykabibble Date: 6/19/2015
Thanks, I think that makes it pretty clear, and is more or less what I had in mind.  I notice though that the SimpleForm example basically decides whether the board is there or not by simply looking at the number of boards returned by a call to KM.GetBoards, and that appears to work well on its own.  Can that be used to set/clear a flag that indicates to the rest of the app whether the board is available or not?  Can all of the library calls be counted on to return some specific exception if the connection is lost?  I don't see any documentation that details what exceptions can be returned by each call.  Is studying the dotNet source code the only way to get this?
I am unclear on one thing - the use of the lock.  When is it necessary to get the lock, and when is it not?  I notice, for example, in the SImpleForm example that timer1_Tick gets the lock to make the MainStatus call, but there are other places where WriteLine and other calls are made without getting the lock.  When is it really required?
Ray L.
Group: DynoMotion Message: 11726 From: Tom Kerekes Date: 6/19/2015
Hi Ray,
I'm not sure if KM.GetBoards would be sufficient.  Actually now that I think about it I'm not sure how expensive of a call KM.GetBoards.  Why not do it the way I suggested?  You might also set a flag on expected availability based on that, but you should realize a disconnect could happen at any time so such a flag is of only limited value.  I can't see a reason to treat any exception differently.  They should all boil down to not being able to communicate to KFLOP.
The idea of the KMotionLock is that when a command (or sequence of commands) is sent to KFLOP and some response is expected it is necessary to guarantee that the issuer of the command receives the response and not somebody else.  So the general sequence should be:
Lock -> Write Commands Lines -> Read Responses -> Unlock
The common case of sending one command and receiving one response cans use WriteLineReadLine and has the locking built in.
Writing one command (WriteLine) is atomic and does not need any locking if there is no response to the command.
Group: DynoMotion Message: 11730 From: himykabibble Date: 6/19/2015
OK, I think for the first time, it's finally sinking in....
Please check my understanding:
1) My primary data source will be MainStatus, so wrap the MainStatus call, and perhaps a few other calls needed for the periodic GUI updates, with WaitToken/ReleaseToken as necessary (see #4 below).
2) Whenever an exception occurs, check the exception, and handle the few that may be "fixable" (I'm sure there must be some that can be treated as "soft" errors, if not ignored entirely...).  For all others (the majority of exceptions, I would expect), simply abort the operation, set a "BoardHasGoneMissing" flag, and inhibit all board-related GUI activities until the board comes back, and the flag is cleared.
3) Whenever the "BoardHasGoneMissing" flag is set, all other calls are suspended until a MainStatus call is completed successfully, at which time the flag is cleared, and everything can return to normal.
4) WriteLine, and WriteLineReadLine are self-locking, so can be called anytime/anywhere without grabbing the lock.  Ditto for any calls that do not generate any response.  All other calls require grabbing the lock.
5) Always, always, always, make sure the lock is released in a timely manner, no matter what path is taken through the code.
 If that is correct, then I think it is now clear, and I can proceed fairly easily.
BTW - The only reason I asked about KM.GetBoards is that is the mechanism SImpleFormCS uses to detect a disconnect, and change the text in the window frame.  Only AFTER this does it try to get the lock and do a GetStatus call.  What you describe now is slightly simpler, and sounds like it should be functionally equivalent.
I'm hoping to make the communications between the GUI thread and my "KMotion thread" simpler than in my first app by using message and buffer queues, to pass data back and forth, so I don't have to mess with thread crossings as much as I did before.  That way, few, if any, locks/semaphores/mutexes/Invokes/etc. should be required, and it should be easy to avoid potential deadlocks.  The GUI thread will send request messages to the KMotion thread through a message queue, and the KMotion thread will carry out the request, and, if appropriate, send a message or data buffer back through a separate response queue.  Each message/buffer/whatever will have one, and only one, clearly defined "owner" at any point in time, and each thread either hands the buffer back to the other side, or releases it, as and when appropriate.  Perhaps a bit "old school", but should be simple and robust.
Ray L.
Group: DynoMotion Message: 11732 From: himykabibble Date: 6/20/2015
I think I'm now seeing a simple way of keeping everything happy in the GUI, using BackgroundWorker threads for communicating with the KFlop.  If I understand the threading issues around the KFlop correctly, as long as I properly use the Lock properly, along with WriteLine and WriteLineReadLine, the Kflop will be happy dealing with multiple BackgroundWorker threads, correct?  If so, then I think the app becomes very straight-forward, using the Update and Complete methods of the BackgroundWorkers for handling all the GUI updates generated by the actions of the worker threads.
I've already got a skeletal app up and running that cleanly handles connects and disconnects, and currently has several threads making asynchronous requests from the KFlop, updating numerous GUI elements, etc. .including several threads updating a single textBox control.  It's all working perfectly so far.  Assuming this approach works, this app will be FAR simpler than my first one, and will take FAR less time to develop, as I can re-use large portions of the UI code from the first one.
Ray L.
Group: DynoMotion Message: 11733 From: Tom Kerekes Date: 6/21/2015
Hi Ray,
That all sounds great (including your previous post items).
But to be honest I don't really understand the need or benefit for worker threads at all (other than the GCode Interpreter Thread that is automatically created when GCode is launched).  KMotionCNC doesn't use any.  It has one GUI Thread and that's it which keeps things simple.  I'm no C# or GUI expert but I would expect that updating the GUI with multiple Threads won't see any benefit.  I could well be wrong and would love to understand this better.
Potentially KFLOP Communication could theoretically be overlapped with GUI updates using one thread for each providing some benefit.  But it seems to me that would only make a difference if the update rate was so fast that the Communication Time + the GUI Update Time was less than the Sample Time.
Keep us posted :}
Group: DynoMotion Message: 11734 From: eric_kato_sanders Date: 6/21/2015
Hi Ray,
I appologize in advance if you already know this and I'm not interpreting what you are doing correctly, but updating GUI items directly from a thread is verboten.  You can send messages to GUI items, but you cannot safely use GUI control references in a thread.
Eric
Group: DynoMotion Message: 11735 From: himykabibble Date: 6/21/2015
It can be done with a single thread, but with a complex app, it can become difficult to keep it responsive.  Using multiple threads can also simplify the code, since certain tasks run with a fixed, simpler function, and essentially autonomously.  The BackgroundWorker was created specifically to be used as secondary threads for a GUI application, and greatly simplify the handling of multiple threads, since it has in-built functions for reporting back progress and completion status.  At a minimum, it makes sense to have one worker thread to handle the periodic GUI updates, and another to deal with the KFlop.  The main GUI thread then has really nothing to do but deal with user events.  Time-consuming operations, like loading the G-code file, are also obvious candidates, since using a worker thread can allow the user to, for instance, continue setting up the machine or the tool table while the file is being loaded.  Multi-threading is ripe with hazards, but the worker thread concept eliminates, or quietly deals with them, without the user having to worry about them as much.
I've now gone through all the functions I had in my old app that communicate with or use the KFlop or KFlop-derived data, and there is really a pretty small number of basic  low-level operations in there.  As my old app did not use MainStatus (it was not working right in dotNet when I wrote the app), many of the old functions now revert to simple accesses to the last MainStatus data.
One question though, re: locking - Using dotNet, do ALL calls other than WriteLineReadLine require grabbing the lock?  It appears to me there are some, for instance CurrentStatus.GetKFlopBitState(), that I suspect only access data within KMController, and don't communicate with the KFlop at all, so should not require grabbing the lock.  How do I know for certain when use of the lock is necessary, and when it is not?
Ray L.
Group: DynoMotion Message: 11736 From: Tom Kerekes Date: 6/21/2015
Hi Ray,
Regarding KMotion WaitToken:  Locking should only be required if you are invoking low level script commands to KFLOP yourself.  The higher level helper classes should have any locking built in and handle that all for you.
You should be aware that the KMotion_dotNet (and underlying libraries) are not necessarily Thread safe.  The WaitToken will allow synchronized communication with KFLOP to keep communications to KFLOP from getting mixed up but that's it.  For example if you have one Thread working to alter and update internal library member variables, axis definitions, status, etc..., and another Thread reading it at the same time, there are some potential hazards.
Group: DynoMotion Message: 11754 From: himykabibble Date: 6/23/2015
OK, I think I understand.  My KMotion requests would be effectively serialized, regardless of which thread initiated them, so I don't think any actual threading problems should materialize.
I've spent the last day having fun with GUI design - getting all the controls to re-size properly when the window is re-sized.  What a colossal PITA!  Most simple controls (Buttons, etc.) will re-size well automatically, but TextBox (like DROs) and Label controls - not so much.  For the DROs, I found the only viable solution was to use RichTextBox controls, and add SizeChanged handlers that calculate new Height, Width, Margin, and Font.Size values on-the-fly.
Ray L.
Group: DynoMotion Message: 11755 From: himykabibble Date: 6/23/2015
Eric,
Understood.  That is precisely the reason for using BackgroundWorker threads - they have built-in methods for, in effect, making callbacks to the GUI thread to give progress updates and completion status.  Those callbacks can then update the GUI, and will always execute in the GUI thread itself, so the updates are completely "safe".
Ray L.
Group: DynoMotion Message: 11756 From: himykabibble Date: 6/23/2015
Good God!  This new Yahoo interface sucks a$$!  The last two responses (from Tom and Eric) only showed up here today, even though they were posted two days ago!
Ray L.
